Pulling my hair out deciding intake...HELP!!!
Old May 1, 2006 | 09:02 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
I am trying to decide which Edelbrock intake to use.I have heard good about performer and rpm and air gap.(I will adapt the intakes to tbi with a 4bbl to 2inch tbi adapter)...I want to use it on my 305 for now but put it on my 350 which will be TBI also....what have you guys had luck with....Im not going real high perf im going to have good flowing heads and headders with a 3 inch single exhaust system (because I cant get anyone here to run duals) thanks for any help....
Old May 1, 2006 | 10:03 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Performer RPM is the best hands down, but getting it to fit under a stock hood takes a bit of magic. I've only heard of one person doing it and it took some fanagling. Also might want to steer clear of the air gap intake, TBI has enough problems with the throttle blades icing with normal intakes. A search would net you a lot more info.
Old May 1, 2006 | 10:12 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I'm happy with my bored out Performer TBI . . . . mmmmmmm torque.
Even keeps the tree huggers happy.
Old May 2, 2006 | 07:45 PM
dwillis's Avatar
Axle/Gears: 3:08
well the reason that im in the market for an intake now is because i now have a steel cowl hood so clearence isn't an issue...and im building an older 350 with older heads so i want to use an approp. intake
Old May 2, 2006 | 09:00 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
I have the Performer RPM and mine fits under my stock hood, i took out the underhood material but other than that it clears fine and runs great
Old May 3, 2006 | 08:20 PM
91RockS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI (L03)
Axle/Gears: 3.73 Truetrac posi
90FormulaWS6, are you happy with the Performer RPM intake? Are you running a 2" air cleaner. You've got a pretty impressive list of mods for a 305. What kind of times are you running?
Old May 3, 2006 | 08:45 PM
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
yeah im more than happy with it, AE with 8746 has been a pain to tune, but im sure that once i get WB ill be doing well and even better with EBL... im running a 3" air cleaner
and as for times... i have no times yet... i havent had the chance to get out to the track... im hoping to get the rest of the car finished up with EBL, WBO2, rebuild the rear, vortec heads & intake... so right now i have no times with the current setup, but once i get time or these mods are taken care of i will
Prodigious
Nov 7, 2020 09:23 AM
86IROC112
Aug 31, 2015 07:00 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
