Building E85 motor
Old May 2, 2006 | 08:24 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Building E85 motor
If you were building a motor to run of ethonal e85 (85% ethonal 15% gasoline) what changes would make mechanically? I know you'd need a large amount of prom tuning, but are there other things that you'd do?
Old May 2, 2006 | 11:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I would imagine the entire fuel system would also have to be corrosion (rust) resistant. Youd also need larger injectors (or more fuel pressure) as you need more fuel for a given ammount of air as ethanol is self oxygenating to an extent, not to mention a different fuel as well.
Old May 9, 2006 | 06:41 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
More tuning, hehe, the optimal stioch for E85 is like 9.0:1. The fact that you have lower compression could hamper you too. e-85 doesn't have the power per pound of fuel as Gas does (worded something like that). You should really have higher compression for e85, like 11:1 or even higher. (e85 has a octaneof like 110-114. Look around on the web and you should fine a good deal of interesting facts.
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
69 Six Pack
Oct 5, 2015 07:51 PM
tricky1
Aug 23, 2015 01:17 PM
overdriv
Aug 20, 2015 03:52 PM
