How complex is TBI?
Old May 17, 2006 | 03:53 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
How complex is TBI?
I've always used TPI or some form of fuel injection, and I'm looking for a budget buildup on an old camaro that has no wiring at all. TPI is too much wiring than what I want to do so I'm thinking I should go carb. However, TBI seemed like it may be a fair compromise. Could anyone familiar with the different forms give me a rough idea of how much more work TBI is than a carbed engine?
Old May 17, 2006 | 04:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
TBI is not much worse then a carb. It still uses a carb aircleaner, and can also use a carb manifold. Need an adaptor plate to mount the GM 2bbl TBI's to one, but the 4bbl TBI units (Holley) bolt right up.
There is a still some wiring to run: CTS, IAT (not required but recommended), TPS, IAC, a couple of wires for the injectors. Then the electronic distributor wires. Not much else.
When I first started with TBI I converted from a carb. I actually set up the electronic distributor and ECM controlled it for a while. Using a carb at the same time. Then dropped in the fuel system and the TBI. Never looked back.
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
