WB tach setup for tbi?
Old May 18, 2006 | 01:51 AM
bluechevy194's Avatar
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
just resently purchased an innovate lm-1 and lma-3 unit i did not get the inductive clamp so it says hear you can connect onto a tach signal, my truck does not have a tach, so can i still hook into a tach signal, if so where would this be?
Old May 18, 2006 | 07:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If your 3rd gen has the small cap distributor with the external coil, look at the harness going to the coil. Next to the heavy pink wire may be a white wire with a quick connect on the end. That is the tach signal.
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
86Firebird86
Dec 26, 2015 07:21 AM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
