Couple pics of my TBI after mods
Old May 28, 2006 | 07:23 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Heres a couple of pics of my tbi on my 92...I did the "ultimate tbi" mods minus the adj fpr for now.Also added a tbi spacer and a pod spacer...I can tell that it has a little more torque now I'll take it to track fri and see if times improve..
Old May 28, 2006 | 07:28 PM
dwillis's Avatar
Axle/Gears: 3:08
heres a pic of the car too
Old May 28, 2006 | 10:27 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Any probs with the tb spacer?
Old May 30, 2006 | 12:16 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
I ran a one inch spacer under my stock hood but I had to use a drop base air cleaner and I cut about a 1/2 inch off of my air cleaner stud.
Old May 30, 2006 | 06:43 PM
Engine: LB9, LB9
Any throttle linkage probs??
Old May 30, 2006 | 09:00 PM
dwillis's Avatar
Axle/Gears: 3:08
The Idle was a little high when i first installed it,But I took the plug out of the TB and Idled it down..The rest of the Idling is computer controlled and had no trouble with that..It was only when I would come to a stop it would idle to about 2500 rpm and gradually decrease.Once I backed off the Idle screw I come back down to about 650 pretty normal now...
I had absolutly no trouble with the spacer or the linkages.
And dont buy the fuel line extensions either all I had to do was unbolt my brake booster vac line from intake and bend the bracket a little to go under the fuel lines and everything lined up perfect and looks like its supposed to
I took a piece of threaded rod and cut and bent it to length..I'm running the spacer and 5" of air filter (double stacked to get up into cowl..14x3 K&N and a cheepie 14x2 paper filter)I just wanted to get the K&N up into the cowl
Your not gonna notice a big differance but I did notice more torque throughout acceleration..
I'm going to track fri and try my luck again..If my clutch will hold out...
Frozer!!!
Jan 19, 2024 04:55 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
justin57
Aug 20, 2015 07:05 PM
matthew911
Aug 12, 2015 09:38 AM
