Zero Fuel...
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Zero Fuel...
I just replaced a valve spring, i also thought it would be a good idea to change the head gaskets-as well... so i put 'er all back together and now--there is NO GAS spraying out of the 2 TBI INJECTORS. So it wont fire-up!! There is gas going all the way to the TBI unit in the lines,but it just will not come through the injectors when i turn it over... The (new)injectors only have around 1 years worth of use too!!! I changed the fuel filter,and the fuel pump is energizing and seems to have enough pressure. The FP fuse by the battery is good,as all the other fuses are. There are no codes stored in the ECM either.
Boy i am stumped, and i need help with this one. thanks, Brad.
90 firebird WS-6 formula 305 TBI.
Car: TWO 1992 CAMAROS 1 Z28 AND 1 B4C
Engine: 1 LQ9 AND 1 LS3
Transmission: 1 T-56 AND 1 6L90
Axle/Gears: 1 4.11 AND 1 3.31 (DANA 44)
ARE ALL THE IGNITION WIRES ON THE BACK OF YOUR DISTRIBUTOR PLUGGED IN? CHECK YOUR IGNITION CONTROL MODUL AND YOUR IGNITION COIL. IF YOUR SPARK PLUGS ARE NOT FIRING THE ECU WILL NOT LET YOUR FUEL INJECTORS FIRE.
WELLS DR140 $34.99 (AUTO ZONE) WITH A LIFETIME WARRANTY
WELLS C846 $17.99 (AUTO ZONE)
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
Could it be a possible ECM issue? I mean it ran just fine, before i replaced the valve spring and head gaskets. Im at a temporary loss of ideas...HELP LOL===Brad.
DO YOU HAVE A NOID LIGHT (TBI FUEL INJECTOR TEST LIGHT)
IF SO HAVE YOU TESTED IF THE ECU IS FIRING THE INJECTOR
IT'S ABOUT $5.00 A AUTO ZONE
IF IT'S NOT CHECK YOUR ESC MODULE (ELECTRONIC SPARK CONTROL MODULE)
WELLS ESC105 $52.99 (AUTO ZONE)
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
