dripping injector
Old Jun 3, 2006 | 11:36 AM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
dripping injector
I noticed yesterday that one of my inj. is kinda dripping at idle but when I gas it,it sprays normal,well as normal as I can tell without something to check the flow,what do I need to check...thx
Old Jun 4, 2006 | 08:20 AM
bj2times's Avatar
Car: 84 Corvette/84 Camero
Engine: 350 sbc
I had a similar problem - found that the injector was not leaking but the gaskets that seal the throttle body around the injector was.
Autozone has some kits that include all the gaskets and other items needed to rebuild the throttle body - it's not very difficult and if one gasket is bad, probably others are also. I also found that the fuel pressure regulator diaphram was rusted and flaking off into the throttle body fuel chambers. The kit will fix that also.
Good luck.
Bill
Old Jun 4, 2006 | 09:44 AM
dwillis's Avatar
Axle/Gears: 3:08
Thanks..I have the kit already to rebuild it but was just wondering if there was anything else to look for...Dave
92-Formula
Dec 12, 2015 10:34 PM
Dwayne614
Sep 29, 2015 11:05 PM
jdperformance
Sep 16, 2015 11:55 AM
webeeZ28
Sep 14, 2015 12:00 PM
blackandblue02
Sep 10, 2015 08:19 PM
