ZZ4 TBI
Old Jun 15, 2006 | 11:58 AM
Casey_Butt's Avatar
ZZ4 TBI
Can a GM TBI system be easily hooked up on a ZZ4 Short Block? I mean, is there anything in regards to sensors, etc on the TBI engine blocks that are missing on the ZZ4 block?
Old Jun 15, 2006 | 08:46 PM
Downzero's Avatar
Car: 88 K5 Blazer
Engine: 383 stroker, TBI with EBL
Transmission: SM 465
Axle/Gears: Dana 60/14 bolt 4.88
The short block will be the same as every other small block chevy.
The majority of sensors screw into and attach to the intake manifold, those will be detirmined by what intake you end up using.
Old Jun 16, 2006 | 02:33 PM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
you will have to put your knock sensor in the new block and thats all water temp is in the head.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
