350 TBI, EZ question...
Old Jun 28, 2006 | 08:38 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
Right Now my Ignition is set at 0*TDC, I get Around 22mpg... Not very powerful above 3000Rpm, What can i set my timing at for More Torque/HP? I have a Timing light, and I want to set my timing For More TQ/HP at the Drag Strip, and then set it back to 0* if recomended.. Thanks, Nick Hall
Old Jun 29, 2006 | 07:19 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
A would have netted you the answers you seek. Most people can run 2-4 deg with no problems. On the top end you can actually use a little more, but it will tend to envoke knock retard in the mid to low rpm range. This is just a generalization mind you, every motor is different, and a lot has to do with the type of gas you have in your area.
Old Jun 29, 2006 | 03:29 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
so if i run 6* i will throw the hp up a few 1,000 rpm's?
if i run 4* its not the best but theres no knocking and im safe from detenation Or however you spell it...
Old Jun 29, 2006 | 03:33 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
NO, it doesn't move the HP curve at all. It will however increase cylinder pressure at all points. Be careful though, because swirl ports don't like more than 28-30* total advance @ WOT and the upper RPMs.
The main thing you will notice will be increased throttle response, increased MPG, smoother take-off from idle, better low-speed pull, and quicker 60's provided the extra timing doesn't just make you burn tires more.
Old Jun 29, 2006 | 03:40 PM
Car: 1988 Camaro
Axle/Gears: 2:73's
alright Thanks! I'll go set the timing for around 3-4*
BTW What did you mean By Swirl Ports dont like more than 28-30* At WOT? Knocking?
Old Jun 29, 2006 | 03:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
What I meant by it, is that the old 36-38* total timing rule does not work for them. You won't necessarily have detonation and ping, but you will start to lose power, fast. I have personally seen swirl ports lose over 20 FWHP on a 250 HP engine by running at 34* timing advance vs. 28. The 10:1 355 ran just fine on 87 octane and 28* timing while making 250 FWHP @ 4,000 and 358 ft/lbs @ 3,400.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
