Fuel Pump...
Old Jun 28, 2006 | 08:58 PM
83Chevy_Camaro's Avatar
Car: 1988 Camaro
Engine: 1988 chevy pickup 350 TBI (rebuilt)
Transmission: 700r4- Bowtie overdrives
Axle/Gears: 2:73's
Fuel Pump...
How Much PSI does the Stock TBI Fuel pump push?
Old Jun 29, 2006 | 09:23 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Would imagine between 10-14 psi...
Old Jun 29, 2006 | 11:43 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Just to clarify, the pump doesn't determine what pressure your fuel system runs at, the regulator does. If you just pinched the line on a TBI pump it would pump up to 90 psi or better. What your looking for is a volume at a certain pressure, the stock pump can barely keep 12psi with the volume demand of an LO3. This is why the TPI pump is so popular, a TPI pump was designed to deliver enough volume to feed a 350 at 43 psi. A pump is capable of more flow at a lower pressure, so a TPI pump will pump a whole lot more at 12 psi. It's the whole P1*V1 = P2*V2 equation at work. Keep in mind for that equation to work you have to be in the same units.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
