I'm sure it's been asked before but I've searched and can't find a good aswer.
Old Jul 9, 2006 | 10:53 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
How good is my tbi 350 going to run with the stock 305 chip and throttle body in my 91 rs. I will be getting a custom burned chip and bigger throttle body later but right now those two are going to be on the car. How much stronger will it feel than the 305 or can I even give it wot?
Old Jul 10, 2006 | 09:01 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is a good chance that the car will run slower than the stock 305. What mods do you have? Basically the car will run like poo and idle even worse on the stock tune. With headers, intake manifold, and TBI spacer my stock cam'd LO3 ran/idled terribly.
Old Jul 11, 2006 | 11:31 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Ewww I thought bolt ons couldnt mess your computer up...
Old Jul 11, 2006 | 01:56 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I never have had that trouble with bolt-ons, but then again my engines were in trucks with truck ECMs. Trucks just dump in the extra fuel under even light loads. They actually benifit more from the mods because it leans them back out to a normal a/f ratio.
Old Jul 11, 2006 | 06:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I don't have any experience with the trucks but my buds '91 LO3 had the same idle problems. A little chip work fixed that though. His wasn't as bad (A4 vs T5 car) but he did have some problems.
Old Jul 11, 2006 | 10:09 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I have no idea what chip is currently in my 350 TBI, but I have strong reason to believe it is the stock 305 one and my injectors dont even match. I have an EBL setup on the way, but in the meantime it runs well enough and is very driveable. Definitely has a little something but I know its got tons more in it. Never drove a 305 TBI for more than 5 minutes so I cannot compare it really.
Old Jul 13, 2006 | 10:23 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
All I've got is a catback. I hope it's atleast driveable.
Ghettobird52
Jul 5, 2024 11:18 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
armybyrd
Aug 10, 2015 09:23 PM
antares57
Aug 6, 2015 07:47 AM
