Checkin Fuel Pressure
Car: 1992 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T5 5 Speed
Axle/Gears: 3.08 LS
On a 92 305 TBI does it have a schrader valve to check fuel pressure or is there no way to check it. Any info will be helpful.
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
alls i can say for sure is that there is no scrader valve for testing on the tbi system. unfortuantely i have no idea how to accurately test this system but i am eager to find out for future knowledge.
Car: 1983 G20 Chevy
Transmission: 4L60
ActronŽ
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I bought that piece. It seems to be very nice quality. Dont try to use the little piece right behind the TBI unit, you will have a hell of a time trying to make that work, especially with gas spilling all around.
Instead go down by the alternater and you will see where the lines go from rubber to metal lines. There is a coupler there that is exact same threads as the schrader valve thing. Put it there. Put it on the thicker line, NOT the return line. I am unsure however if I check for leaks and leave it there always, or just put it in, use it, and remove it every time I need to check my FP. Right now its just left in there, has been for a couple months with no problems so far.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
