heads. stroker kit?
Old Jul 11, 2006 | 09:58 AM
truckerz's Avatar
Car: 1989 Formula
Engine: 355ci HSR SBC
heads. stroker kit?
After a few posts on this site and a lot of research, I found that for a mild biuld (250-325hp) of the stock 305 170hp LO3
Vortec Heads, Matching Edelbrock Mani, Holley Tbi unit W larger ports,
Comp Cams camshaft (just a bit warmer due to the lift problem with the vortecs?),
Has anyone heard of a stroker kit for the LO3?
If so, any problems with it?
PROM Upgrades, 180 degree therm. accel ignition and dist. taylor wires
Hooker headers, High flow cat and 3" exaust.
B/M Shift kit, clutch upgrade, 2200stall, Stronger U joint.
Switch from stock rear to 3.73 or 4.10 posi?
With this laundry list, what gains are expected? and is this do-able?
Old Jul 11, 2006 | 10:47 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Only problem I see with the stroker kit is that it's fricken expensive, you can buy a 350 block and rebuild it for less than the cost of the kit.
Other than that your list looks pretty good, just need to change that "prom upgrades" to a "learn to burn my own prom" and you'll be on your way to a 300 hp 305 or a 350 hp 350.
junior419
Apr 7, 2025 11:35 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
New2Chevy
Sep 28, 2015 12:35 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
