HELP Removing TB right now!
Subscribe
Jul 12, 2006 | 12:18 PM
I've disconnected all my sensors, vaccume lines, 2 fuel lines, but HOW do i properly remove the throttle linakge on the drivers side of the TB. I dont see any clean reattachable ways to remove it w/o cutting cables...
Reply 0
Jul 12, 2006 | 12:47 PM
There should be a little round clip on the throttle cable post that you sort of take a small flat head screw driver and seperate a little and the clip should come off and then the cable should come off. If you have cruise then after you remove the throttle cable open the throttle by hand as far as it will go and pull the cable towards the front of the car and you have to use the flat head screw driver again and pry open the little clip at the end of the slot on the cruise cable, then the cruise post willl slide under tha clip and come off. Let us know if it works!
Reply 0
Jul 12, 2006 | 02:15 PM
Got it thanks!
Reply 0
Subscribe
