Rocker Ratio?
Old Jul 14, 2006 | 02:10 AM
bluechevy194's Avatar
Car: 92 c1500
Engine: 355ci
Transmission: 700R-4
Rocker Ratio?
i'm running a comp cam that has a duration of 212/218 @ .50 and the lift on it is .449/.456, w/ lsa of 112. im wondering would it be worth my while to throw on a set of 1.6 rocker arms? i have had this engine tuned for about a month now, and it passed smog. i would only want to do it if the power gains were decent. would this make it any more difficult to tune?, i live in cali so i have smog ****'s
Old Jul 14, 2006 | 02:31 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
it should come out to .485/.496.I think if you were able to tune it in the first place this won't be much more of a stretch.IMO i think it will be very benificial for you to put the rockers on.One ?. what heads are you running?Be sure your heads can take the lift of the cam before you install them though.The extra lift of the rockers could cause problems if your running stock unmodified heads.
Old Jul 14, 2006 | 07:49 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Most stock heads won't take moren than .460 lift, also make sure you get long slot rockers, most 1.6's are long slot but I have seen some that aren't.
Old Jul 14, 2006 | 05:59 PM
Car: 92 c1500
Engine: 355ci
im running s/r touquer heads with 2.02/1.6 valves im pretty sure they can take up to over .500 lift
Old Jul 14, 2006 | 06:15 PM
Well I guess you should be fine then.go for it.
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Damon
Sep 26, 2015 04:29 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
