ticking help
Car: 1989 rs camaro
Engine: 305 TBI
Transmission: auto
ticking help
Hi all my LO3 is making a ticking noise I think it is coming from the valve cover it is only on the driver side I took a piece of wood and felt across the valve cover and about where cylinder 2 is I can feel some thing hitting and only right before the pvc valve and about 1.5 inches toward the back of the car so I think it is a rocker arm that lost a push rod or maybe a lifter what is yall’s thoughts on it I will be pulling it on Tuesday when my grandfather is over so help please thanks in advance
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It sounds like you have traced the problem down enough to start getting some tools out. I would remove the valve cover and inspect the valve train. I would check valve lash and inspect the rockers, pushrods, springs, retainers, and rocker nuts. Have you recently over-reved the motor? How many miles are on the motor? You could have a bend pushrod (common for a severe over-rev) or a broken valve spring.
Car: 89 Camaro RS
Engine: 305TBI
Transmission: 5sp
I have the same ticking noise in the same spot on my motor. I figured it is an exhaust manifold leak
I have a stock 305 TBI V8 with 208,000 miles on the clock.
Where in cinci are you at ShiftyCapone?
I have a stock 305 TBI V8 with 208,000 miles on the clock.Where in cinci are you at ShiftyCapone?
david068513
Sep 13, 2015 11:24 AM
