L-98 with LO-3 induction
Old Aug 1, 2006 | 09:21 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I decided to ditch all my tuned port stuff on my engine and run TBI. This is whats in the car, I also ditched the edelbrock headers in favor of a TPI exhaust system.
Lets not bash this because this is a california car and TPI is a visual fail where as TBI passes as long as the air cleaner isn't removed
1990 vette shortblock with iron 083 heads
TPI fuel pump
TPI exhuast system
373 gears
5 speed
now to the questions
will a 350 esc knock sensor and est module really help much ?
would I benefit alot from 350 injectors ?
would a tbi edelbrock manifold help very much ?
also whats the correct VSS gm part number for this TBI system the car has all 1990 electronics in it.
the car seems to run real good, only code is 24 which is vss related. should I stay away from a different prom since it does run great already ?
Old Aug 1, 2006 | 09:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will indeed need 350 injectors and knock sensor. They are key to this swap. If the edlebrock headers have AIR provisions I would run those. They should be smog legal for California and will be better than the stock exhaust manifolds. An edelbrock TBI intake will be fine but you may want to have it bored to 2" if you plan on making more than "stock" power. The key to this set-up, as with all TBI set-ups is chip tuning. Fast355 will chime in. He has completed numerous TBI to TPI and TPI to TBI swaps. Just curious but what are your reasons for the swap?
Old Aug 1, 2006 | 10:11 PM
Jproz1167's Avatar
car originally was a LG-4 nuff said LOL ... that and it couldnt get through emmissions test
Old Aug 6, 2006 | 08:19 AM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
This site will help ya
There is a guy in Syracuse that built a nice 350 with TBI and chronicled it on a web site. The site is loaded with usefull info - Brian's 1991 RS. I think he hangs out in here as z28boy or something like that. Met him a couple of times and he is a decent guy, but he may have some of the info that you need.
Good luck!
-Sean
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
aharvel50
Sep 21, 2015 07:31 PM
Magman
Sep 13, 2015 08:43 AM
Magman
Sep 13, 2015 12:14 AM
