Aeromotive FPR Q?
Old Aug 8, 2006 | 10:09 AM
Ronny's Avatar
Aeromotive FPR Q?
my unit #13301 has what i thought was a VAFPR similar to the GM unit.
now i find out it is suitable for boost only @ 1/1. they state "fuel pressure rises at 1/1 ratio" is that the exact opposite of the design of the GM unit some of us used?
what does 1/1 mean?
Old Aug 22, 2006 | 11:20 PM
reeder5001's Avatar
1/1 means that the fuel pressure rises 1 lb per lb of boost.
Old Aug 23, 2006 | 09:37 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Unless I'm completely confused here, I'm pretty sure that works just like all other vacuum adjustable FPR when not under boost. All MPI setups need the vacuum reference to compensate for the fact that the injectors see manifold vacuum. The vacuum reference is used to cancel this out and make the injectors act like 24 lb/hr or whatever size they are at all times. We use this same feature to make our injectors act smaller at idle and bigger at WOT, completly opposite of why MPI setups use them.
Old Aug 23, 2006 | 09:43 AM
Ronny's Avatar
Monte: so manifold vac is read if the line is attached to a vac source with no boost? and with presence of boost there is no vac and a positive pressure in manifold results.
like in -1.00 = vac and +1.00 = boost.
both provide the same amount of fuel?
reason i am asking is that i just added EBL and it supports the VAFPR. i used one(GM) 3 yerras ago as a substitute for tuning and as you would expect was a failure. now with my large inj's(80) at 25 lbs FP i could possible drop down to say 15 lbs FP and have adequate fueling up top. may result in better tune. maybe not.
Old Aug 23, 2006 | 12:10 PM
BMmonteSS's Avatar
Car: 84' Monte
Your correct, whith a MPI system that FPR would give the motor the same amount of fuel at all times uner vacuum or boost.
You might run this by Rbob, I think he has the VAFPR table setup to work well with the stock GM regulator. You can still retune that table to fit your FPR, it might just be an extra step. Judging by the fact that Rbob made this adjustable I assume that every brand of regulator works a little different.
Old Aug 23, 2006 | 12:46 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, will work with different regulators. The regulator I am using isn't quite a 1:1, although it is supposed to be. Eh, it was inexpensive.
Ronny, if you'd like email your current BPC for the setup. This would be for the injectors and fuel pressure that you are using. I'll run the numbers are email you back the table values to use.
Using a VAFPR with the EBL does make a difference. I was rather surprised at how much better the engine was at idle and coming off idle. Just be sure to use a full time vacuum port for the regulator.
RBob.
92-Formula
Dec 12, 2015 10:34 PM
mike22115
Sep 28, 2015 04:49 AM
Lmancha96
Sep 25, 2015 08:11 PM
R13_Braz
Sep 18, 2015 05:00 PM
Strick1
Sep 4, 2015 07:11 AM
