92 RS Wont Start
Old Aug 22, 2006 | 02:35 PM
3FKS484's Avatar
92 RS Wont Start
I am new here and need some help bad. I just did a basic tune-up, plugs wires cap rotor and reset timing to 2 degrees retarded. Now the car gets hot and the fuel stops flowing to the TB. Any body got an idea ????
Old Aug 22, 2006 | 03:16 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Try advancing your timing first, there's no real advantage to retarding your base timing below 0*
Old Aug 22, 2006 | 03:18 PM
3FKS484's Avatar
That was my fine typing skills it is actually about four advanced. Spark is great the fuel just stops at the injectors. I am starting to think it is the relay...
Old Aug 22, 2006 | 04:20 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Change fuel filter (although that probably isn't your primary problem).
Check the relay, there's prolly where your problem lies.
Old Aug 22, 2006 | 04:25 PM
3FKS484's Avatar
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Old Aug 22, 2006 | 07:21 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
if it's the relay you will still be able to start it just crank it for a few seconds 8x's or so and it will start, it won't get fuel until the engine makes enough oil pressure because, of gms oil pressure switch or as i like to call it *the anti crash and burn switch*
If you'd rather not crank it so much then swap the fan relay which is directly next to it with the fuel pump relay and it should fire right up if the relay is your problem.
anyways i wouldn't even look at the relays if you can hear your pump click on when you turn your key to the on position.
Old Aug 23, 2006 | 10:22 AM
3FKS484's Avatar
It wound up being a short on the firewall. Back on the road today
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
