lt1 top end swap
Old Aug 26, 2006 | 03:33 PM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
lt1 top end swap
i was told this is possible but i dont understand how it would wrk. if it is possible what all would i need off the lt1 motor???
Old Aug 26, 2006 | 04:13 PM
SchwarzCamaroRS's Avatar
theoretically everything thats not a shortblock part... im not sure of the gen II SBC coolant paths line up with those on the heads of the gen III... LT1's use reverse flow cooling so you would need the new water pump that flowed that way as well... all in all, its more trouble than its worth, im sure of it... for the price you would spend on the LT1 parts you could get a 350TPI setup easily built for 300+whp...
Old Aug 27, 2006 | 02:50 AM
KILGORE92's Avatar
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
thanks i kinda thought that but the more i looked into the more i saw it possible. anyways thanks for the help
Old Aug 28, 2006 | 08:55 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
With the amount of other heads out there I would be reluctant to attempt this. It has been done a few minutes with the search function should uncover tons of info dedicated to the this topic.
midge54
Dec 27, 2019 04:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
