EGR problem.
Old Aug 28, 2006 | 09:02 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
EGR problem.
I have done some searching and can't find what I am looking for. I will make this quick. I have a 89 T/A TBI. When I drive on the highway my check engine light comes on sometimes. I check the code and it's an EGR code. I replaced the sensor that controls the EGR valve but it still does it. I checked th vacuum lines and they aren't broken. Do i need to replace the EGR? Thanks.
Jason
Old Aug 29, 2006 | 06:15 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
awesome signature and i would say that yes most likely you will have to but, i myself would probably unbolt it and spray some carb cleaner all over the passage and clean the valve up (just not with carb cleaner) it will eat rubber up if you give it time. If that doesn't fix it you will probably need a new valve.
Old Aug 29, 2006 | 10:00 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
It will help a lot just to clean it out! Wait 'till you see what's actually in there when you do!
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
