update on the mods...
Old Sep 7, 2006 | 10:11 PM
92green3RdGen's Avatar
well im still goin with the modding of my trusty 305
well i have gotten my heads and my hedders so far, the heads i ordered from jegs they are the 64cc cast iron vortecs, and the hedders is the edelbrock tes system....now i am really lookin at the comp cams xe262h
Xtreme Energy XE262H Hydraulic Flat Tappet Camshaft
Lift: .462"/.469"
Duration: 262*/270*
Rpm Range: 1300-5600
would this be a good cam for the street/strip? also im upgrading to a 670 cfm and has anyone used the vortec tbi intake? ill need a new fuel pump and also i will need to burn a chip for my car
some advice would be great....
Old Sep 8, 2006 | 07:17 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
If you really have a 92 with the original 305, then you have a roller cam..... and the one you are looking at is a flat tappet. Also, if you ordered L31 heads, you need an intake that will work with it... which means either the Vortec TBI intake or a Vortec carb intake with a TBI adapter plate.
Old Sep 8, 2006 | 03:57 PM
already knew about the intake stuff but i didnt know my engine had a roller cam in it so....what should i do im still looking for the same specs as the xe262h...anyone know a good roller cam?
Elephantismo
Feb 13, 2019 12:51 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
aharvel50
Sep 21, 2015 07:31 PM
