2bbl TBI HP potential
Old Oct 1, 2006 | 12:45 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
FWIW, I have been running 35 lb/hr 2.8 injectors at 45 PSI lately on an essentially stock 350 TBI (TPI pump/Experimented with the regulator spring with ones I had laying around). That is about 68 lb/hr from 35 lb/hr injectors or roughly 2x stock. I am having no problems with a NEW stock type diaghram or the injector o-rings at this pressure. The injectors are a little noisy, but current draw really hasn't changed much if at all. The injector spray is barely visable and I have hit 20 MPG highway in a 1991 G20 Van 350/700r4/3.42:1 combo. Very smooth idle, seamless throttle response, and good torque.
Old Oct 2, 2006 | 03:36 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
20 MPG ???? Holy
Old Oct 5, 2006 | 04:29 PM
91chevz71's Avatar
I should have no problem feeding a 330 horse small block with 68's at a higher psi, then. Where is that formula to find out howmuch psi to run?
Old Oct 6, 2006 | 06:51 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I would be interested in the limits of the stock fpr if anyone could add that.
I want to run a walboro pump that puts out 40-50 psi. Will I run into problems reducing the pressure below a certain amount?
I don't mean to jack the thread, but I feel this may be relevent to the topic as well.
Old Oct 6, 2006 | 10:36 PM
Drac0nic's Avatar
I'm running a Walbro 307M on a 4.3L V6 with no problems, I made my FPR adjustable but hadn't touched it after the FP install. runs fine, I may try leaning out the fuel curve some but that's unrelated.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
