Got my first data log... well kind of.
Old Oct 7, 2006 | 10:39 PM
Blazin4x4's Avatar
Car: 1988 Chevy silverado K5
Engine: 350 bored .030, crane cams hyd bluprint l-79 cam 447 lift 272 dur, camel hump heads port and polished 1.94 1.50, afterburner headers and y pipe, holley 670 cfm tbi, holley projection dual plane manifold, accel high pressure fuel pump, 3 inch exhaust
Transmission: 700 r4 with corvette servo and shift kit.
Before it caught on fire I got these numbers. It runs sooo rich and won't idle. I didn't get it fired up but this is what I got while it was cranking...
Sorry for the bad screen shot... Is there any way to show the aldl stuff without pasting the screen shot to paint?
to fill in the blanks IAC was 100, INT was 128, MAP was 98.9 kpa
Any suggestions for getting the thing to idle or start? Ever since I put a muffler on it won't fire up like it did with open headers. I've already changed the bpw using a calculator and I pulled all the timing advance out to so I can get a baseline idle.
I'm think IAC but I don't know what to do. I need to lean it out at low rpm. Can I do this with the IAC?
Old Oct 8, 2006 | 12:50 PM
jase's Avatar
do you have an oxygen sensor hooked up at all?
Old Oct 8, 2006 | 05:05 PM
Blazin4x4's Avatar
yes but it didn't fire up... just cranked and sputtered and popped a little... if I remember correctly it was .394 volts at the highest.
Old Oct 10, 2006 | 05:53 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Edit: I just noticed you said you got those readings while cranking the motor, that won't tell you a thing. You really need to get your injectors fixed before you go any further.
Falcon50
Aug 22, 2020 03:26 PM
Gunner242
Dec 25, 2015 04:49 PM
bjpotter
Oct 4, 2015 07:48 PM
hartsmike
Oct 2, 2015 07:11 AM
