stalling problem
Old Oct 10, 2006 | 08:57 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
stalling problem
i adjusted my timing on my stock lo3 to about 5* advanced and sometimes when i start it it'll just quit, and then you have to restart it again, sometimes you have to start it multiple times. what could be the problem?
Old Oct 19, 2006 | 02:00 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
This is a fairly common problem. One issue is that the old C3 ECM doesnt have any variable crank fueling capability. The newer PCMs can adjust their fueling based on how many times the engine has cranked over. They start off with a large shot of fuel to prime the manifold, and then lean out for startup. This really helps get the engine fired up almost immediatly when its cold without any stalls. Also, there is a ramping multiplier for the timing in the ECM. If the ECM ramps the timing in too slowly, the engine will fire, and stall. Adjusting the base timing may make this even worse.
Basically, if the rest of the car is sound, youll have to mess with the cranking AFRs and ramping multipliers to get it to start reasonably well, but this requires that you be able to burn a prom. The other alternative, which is easy, is to crack the throttle open. That will help prevent it from stalling. Also, adjusting the park IAC counts may also help (more min air with less IAC helps the fuel distribution).
Also, did you remember to disconnect the EST before adjusting the timing? Stupid question, but it happens every now and then.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
