New Fuel Pump?
Old Oct 16, 2006 | 03:43 PM
evolution_star's Avatar
New Fuel Pump?
I have a 92 305 tbi that has sat for 2 years and I just recently replaced the starter on. Well after i replaced the starter. It wouldnt start. It turns over but it doesn't fire. I pour same gas down the throttle body and it fire right up, but would stay running. When i turn the key on, i dont here the fuel pump kick on. I figured it was the fuel pump. I decided to disconnect the fuel line going to the Throttle body and turn the key to run position to see if any gas was coming up and there was a small trickle, that kind of stumped me. I dont know it has enough pressure or if the pump is shot all together. Any suggestions?
Old Oct 16, 2006 | 04:25 PM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Disconnecting the fuel pump line to the TBI is not a good way to test the pressure. A fuel pressure tester will do that. However, if you have just a trickle of gas coming out after disconnecting it. If you have just 3-5 lbs pressure out of the line at the TBI and you do not put a hose over the end prior to cranking the motor, you will get soaked with gas. I know, I've done it. I got so much gas out at what was about 5 lbs, I did not think that anything was wrong with the FP. Of course, that was pre pressure test with a gauge. Based on the trickle and the fact that you do not hear it running, it sounds like it may be a bad FP or a clog in the line or insufficient power to the FP.
Old Oct 18, 2006 | 05:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sounds like a dead pump. I would suggest a TPI and or Walbro pump as a replacement. They are often cheaper than a stock replacement and will support more power down the road should you decide to switch a to multi port set-up.
Old Oct 18, 2006 | 06:10 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Since the last thing you dide, was adjust electrical connections, you might just want to double, and tripple check your wiring. I would also try to hook up the fuel pumps hot line to 12v power, and see if the pump actual pumps that way or not.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
