TBI sticking at closed throttle.
Old Sep 24, 2000 | 07:48 PM
Chuck's Avatar
1989 305 with TBI. I've replaced cable, but
throttle sticks when fully closed. Once
it is slightly open, all is smooth.
Any fix?
Thanks!
Old Sep 24, 2000 | 08:09 PM
89BlwnRs's Avatar
I have the same problem. If you look at the driver's side of the TB where the cable comes up, you'll see a hollow tube with a flared end on it. When the throttle is closed this flared end rest on something and I believe they kind of stick together.
My problem is most evident when I slam the throttle closed, if I let off it very gently they problem is barely evident.
I'm so used to driving with the throttle sticking that I've never messed with that part. Take a look and see if you know what I'm talking about, and if you fix it, let me know what you did.
Jason
[This message has been edited by 89BlwnRs (edited September 24, 2000).]
Old Sep 24, 2000 | 08:55 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
have you messed with the idle adjustment? that sounds alot like someone backed out the idle screw to compensate for a high idle and the only thing stopping the throttle are the blades jamming up against the TB bore
MustangBeater20
Oct 29, 2022 09:20 PM
Jorlain
Oct 8, 2015 01:57 AM
TheTraut88
Sep 7, 2015 05:22 PM
lt1z350
Aug 28, 2015 05:57 AM
