Need part # for Mr.Gasket Non drop aircleaner!
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Does anyone have that # for the MrGasket non drop aircleaner assembly? What size filter does that use? And are there any difficulties I should know about installing it (clearences to throttle cable, distributor, etc.)
Thanks!
Thanks!
Open Element Air Cleaner
I used Mr. Gasket non-drop base open element #1680, Mr. Gasket oil breather cap #2057 and 14x3 Purolator brand air filter #A60074. It's pretty basic. Just take off the stock unit and put on the open element. then you need to either remove the IAT sensor from your stock air cleaner or get a new one. Once that's taken care of your set. Note: if you want a K&N filter the 14x3 is #1650.
My car is the perfect women. She's braless, won't talk back and loves a good beating.
1989 Camaro RS L03 w/ WC T-5
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Thanks for the help! I couldn't find this info anywhere else and I need to get one ASAP, my stock one is a little screwed up.
Thanks again
Joe Caccia
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, Soon to have SLP 1 3/4 headers and a few other things.
Thanks again
Joe Caccia
1992 RS
LT1Formula
20
Nov 14, 2015 12:02 AM
