160 thermo. ?
Old Sep 30, 2000 | 02:22 PM
500Z-YA's Avatar
160 thermo. ?
Does switching to a 160 thermo. only increase performance w/ a modified PROM, or will it help w/ the stock PROM as well?
Jeff
'71 Datsun 240Z
'91 Camaro TBI 305 drivetrain
Build it, Drive it, Improve it...
Old Sep 30, 2000 | 02:55 PM
Andy89RS's Avatar
It'll help with the stock chip, but an aftermarket one is designed to be run cooler so it will be able to take advantage of the lower temperatures better.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Sep 30, 2000 | 03:53 PM
500Z-YA's Avatar
Thanks Andy!
That's what I figured. Since I haven't done the custom chip yet w/ timing advances etc.,
I wondered if I should just put the thermo. in now anyway. It's so hot here, it can't hurt. Thanks again, Jeff
'71 Datsun 240Z
Old Oct 1, 2000 | 08:33 PM
GH6801's Avatar
Are those 160 T-stats 50 state legal?
Old Oct 1, 2000 | 10:06 PM
500Z-YA's Avatar
I'm assuming you mean for emissions?
I would imagine as long as the vehicle passes inspection, all is ok. In my case I only have to pass standards for a '71 Datsun.
'71 Datsun 240Z
Old Oct 2, 2000 | 04:02 AM
Twin_Turbo's Avatar
160 stats seriously lower engine operating temperature and thus oil temperature. If you live in a not so warm climate don't do it. Watch the oil temp (if you have a gauge) if it doesn't reach 185 degrees DON'T use the 160 stat. Lubrication characteristics of engine oil seriously worsen below 170 degrees. Engine wear increases dramatically.
Marck
Old Oct 2, 2000 | 08:45 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I installed the hypertech thermomaster PROM
chip and bought the thermostat and cooling fan switch at the same time. they claim that without the low temp thermostat the car will ping (detonate)from the advanced timing. but I haven't bothered to install the new stat or switch and I have driven the car all summer without and problem.
I don't expect much of a power gain from them but I will post my results.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Pinguiclia
Oct 12, 2015 04:47 PM
Nervous2
Oct 8, 2015 10:53 PM
