surgeing at idle and part throttle help!?!?!?
Old Oct 3, 2000 | 09:53 PM
SCOTTCAMARO1's Avatar
it acts like a bad miss but it takes gas to good to be anything to major.the first time i noticed it i was raceing a stang just shifted into 3rd shifted at 6 grand and my check engine lite came on i let off and pulled over it was missing pretty bad at an idle i unhooked the map sensor and hook it back up the light went off and hasnt been back on since but i still have the miss im lost on this one
Old Oct 4, 2000 | 12:04 AM
Dan W's Avatar
What was the code?
Old Oct 4, 2000 | 04:30 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
one stuck injector, other one trying to compensate.
tps wire or something along there has gone bad.
check those.
Old Oct 10, 2000 | 12:13 AM
ok it came up a code 32 which was suposed to be the map sensor i replaced it.still haveing the same problem but no codes are comeing up now.i was talkng to a mechanic and he said to clean my idle air control motor its got to where it dies when i drop it in gear any ideas
Old Oct 10, 2000 | 04:25 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
check your TPS, and clean out your IAC passage also reset minimum idle
code 32 is for egr, not map sensor
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
1nastygta
Aug 8, 2015 07:38 PM
