need TBI help
Old Oct 6, 2000 | 09:27 AM
Matt98SS's Avatar
need TBI help
ok trying to get this 87 Chevy work van with 350 TBI motor started.
put a new battery in, can get it started once in a while - other times it sounds like the starter is not engaging?
anyways when I get it started I have to pretty much floor it to keep it running, and then after about 1 min it will start loosing RPMs and just die even with the pedal to the floor. like it is not getting fuel after a short time.
anyone have any direction? it was sitting for around 2 months but was driven before that
Old Oct 6, 2000 | 09:36 AM
Bill91Z
Guest
Posts: n/a
Yo Bro, I think the first thing people will say is fuel filter or pump. Have you checked that? Well, that's the extent of my knowledge on TBI. later
Old Oct 6, 2000 | 09:37 AM
Bill91Z
Guest
Posts: n/a
ooh one more. Doesn't a TBI have a MAP sensor? It doesn't skip or anything does it. Similiar to the symptoms of a bad MAP except there is usually a skip. probably no help huh? lol
Old Oct 16, 2000 | 12:07 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I was once told that to check the MAP sensor, you gently tap the sensor, while the engine is idleing. If the car's idle fluctuates, then you have yourself a bad MAP. Dont know if you want to try this out, its purely heresay. Peace.
1988 Firebird Formula 305 TBI, T-Tops, RED.
Of course ... 5-Speed
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
