tuning with o2 sensor
Old Oct 22, 2000 | 09:02 AM
Get Blown ?'s Avatar
Do I just tap into the o2 wire then ground the negative terminal from the digital volt meter to the body?
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
ICQ: 61342629 AOL IM: BlackSunshineZ28
Old Oct 22, 2000 | 07:05 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
thats pretty much how it goes
I explained it all in the tech section
Old Oct 22, 2000 | 08:18 PM
Yeah I read the tech article, but for some reason I was thinking you meant to chop off o2 wire which made no sense to me at all.
On another note: To adjust the TPS sensor we just do it the same way TPI does correct?
Old Oct 23, 2000 | 12:50 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
pretty much except our idle voltage should be higher ive seen everything from .7 to .95 in the service manuals. Just adjust it to where you get past 4 volts wot
Old Oct 24, 2000 | 12:23 AM
ok, thanks Pablo.
antman89iroc
36
Jan 31, 2016 08:42 AM
meeklay812
Oct 1, 2015 03:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
m00n420
Sep 11, 2015 02:39 PM
