Which is best Holley 670 or 650 TBI???
Old Nov 14, 2000 | 01:51 AM
Metallica383's Avatar
The 670 is a 2 bbl and the 650 is 4bbl so which would be the best for around 300 HP to maybe 350 hP?
Old Nov 14, 2000 | 12:31 PM
badbird88's Avatar
look at my sig, I'm doing just fine with my 670 for the 300hp range and maybe more. If you are running a 383 like your name implies then I would go with the 4 bbl. Either way you will need a custom chip among other changes to the sensors.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Old Nov 14, 2000 | 12:45 PM
Scott C's Avatar
badbird,
How is your car running? Did you get everything worked out? Let us know!
-Scott
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
makaveli09
Sep 15, 2015 10:43 AM
Magman
Sep 14, 2015 01:30 AM
