L69 dual snorkel fit on 91firebird with ac?
Old Nov 27, 2006 | 07:06 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Anibody using L69 dual snorkel on a 89-92 tbi f-body with air condition and air on passenger side? Is there anoff space for the passengers side snorkel?
Tank you.
Old Nov 27, 2006 | 08:24 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
no.
Old Nov 27, 2006 | 11:24 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
It can be done. The air cleaner itself fits just fine, as long as you remove all the AIR stuff. I am still in the process of getting the hoses and scoops set up. If you get a collant reservoir from the early (82-88?) third gens you will have more room. Maybe in a paycheck or two I will order the hoses from Modern Day Muscle.
Old Nov 27, 2006 | 03:39 PM
thomas1976's Avatar
Car: 91 Trans am
Thank you. Id really like a dual snorkel on my LO3.
I saw a pic of one with dual snokel somewehre but dont remember were and if he had air.
Interesting the early coolant reservoir. But I cannot go without air.
How mutch would you need to raise the air cleaner to get over it? or is not anoff hoodclearence?
Old Nov 27, 2006 | 04:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by DLV555
The air cleaner itself fits just fine, as long as you remove all the AIR stuff. If you get a collant reservoir from the early (82-88?) third gens you will have more room.
I have no experience with TBI, so I may be off-base. The L69 cars that the dual snorkels came on were equipped with both AC and emissions, so that shouldn't be a problem (as far as I know). Also, wouldn't the coolant reservoir be exactly the same, 82-92? Check the pics/info out in the following link:
https://www.thirdgen.org/forums/tech...t=dual+snorkel
There's not really a clearance issue. Again check the link to see what members with LG4's (including me) did.
Should anyone be interested, I have a dual snorkel for sale. Search my name in the classifieds for info/pics.
JamesC
Old Nov 27, 2006 | 05:09 PM
thomas1976's Avatar
Car: 91 Trans am
Thank you, Wery helpfull!
Old Nov 27, 2006 | 05:17 PM
DLV555's Avatar
Engine: 400 SBC
Axle/Gears: 4.10
Yes they did, but the a/c compressor was on the other side compared to serpentine cars, and the alternator that was in that location is positioned slightly differently. Also, from what I have seen the early cars did have a different reservoir. In that thread you listed azvolfan has a serpentine car and you can see he must have relocated his coolant reservoir to allow room for the hose. In those cars the a/c compressor and the reservoir almost touch.
As far as the AIR is concerned, I removed mine at the same time I added the air cleaner, so I cannot be 100% sure they won't fit, but I remember test fitting it and coming to that conclusion.
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
