Why is the round style open element better than the edelbrock "pro-flo"?
Old Nov 20, 2000 | 05:03 PM
Zant69's Avatar
Why doesn't anyone talk about the edelbrock pro flo? (the triangular one)It gets air from the sides AND top...the regular open element cleaners only get air from the sides. Is there a reason that air should only come in from the sides? I have a 14" by 3" K&N and a edelbrock pro-flo...and I couldn't tell a difference between them. But, an advantage with the edelbrock was that the edelbrock is small, easy to fit in there, NON-drop base, and gets air from all directions.
just wondering..,Thanks for any info...
Brant
http://www.edelbrock.com/automotive/...aners/1002.jpg
Everything I know I learned by messing it up at least once.
Old Nov 20, 2000 | 09:25 PM
Andy89RS's Avatar
I think alot of it has to do with taste. I personally don't like the looks of the Pro-Flo. Also, while it does get air from the sides and the top, it is smaller, so total filter surface area is pretty close to the same. I've also heard some people mention that they've heard of, seen, or had their own pro-flo start to shed little bits of the foam filter assembly.
Old Nov 20, 2000 | 11:52 PM
Mike92's Avatar
That and reports of parts of the element getting sucked into the engine or something like that.
Old Nov 21, 2000 | 01:28 AM
mike ghoul's Avatar
the k&n is the superior air filter. It's design flows more air than an edelbrock foam filter. Also you can now purchase tops for the k&n that are made of their filter, so it will flow throught the top as well.
The edelbrock foam type filter does fall apart as well, over time little pices of the foam fall off, and into the TBI unit.
Old Nov 21, 2000 | 09:56 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Brant
It's just about good enough to catch small rocks, IMO.
Best air filter I found for the TBIs was using a Moroso 14" drop base with a GM truck 3/4" spacer ring between the housing and TB
Old Nov 21, 2000 | 11:02 AM
Scott C's Avatar
I used a Pro-Flo on my last RS with TBI. It's a neat looking design, but not very functional. It uses a plain old foam "element" (which is really just a piece of foam), that appears more restrictive than most. The other downfall is that with the air only coming in from the top, that is where our cars don't have alot of room. Between the TBI and the closed hood, there is very little room for good airflow.
That's really why a 14" open element is better.
Old Nov 21, 2000 | 02:40 PM
Get Blown ?'s Avatar
The Edlebrock Pro-Flow filter is gay! My ******* friend had one on his 2ndgen and lets just say after a month half the filter was burnt up. You want to know where it ended up? Right in his carb. nuff said
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
Old Nov 21, 2000 | 08:01 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
My brother just got one for his 350 that he just finished building for his El Camino.I thought about the same question as this post,but now that I think about it,that foam element sure does look like the kind to deteriorate after time and get sucked into the engine.But couldn't a paper element be custom made?
"So,tell me Mr. Stang. How's life like living in the exhaust of a Chevy V-8?"
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
Flowmaster cat-back
TBI mods
383 implantation soon to come.
[This message has been edited by RSpeed (edited November 21, 2000).]
Old Nov 21, 2000 | 10:31 PM
Zant69's Avatar
It's not like You could make the LO3 any worse with it...
I've seen the K&N top filter, too...it looks really cool...looks like a good way for K&N to suck another $40 bucks out of My wallet, too. They could've made something like the pro-flo except with a K&N element in it.. but noooooo....
Anyway, thanks for the usefull info.. I had no idea about those things shredding up and getting in the intake. wheww! That's something I usually learn the hard way. hehe..
Hotrodboba400
Dec 10, 2019 07:07 PM
SG91camaro
Sep 5, 2015 10:27 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
luvofjah
Sep 3, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
