cold-air-induction for TBI Formulas
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Thought you might like to see this: my fully functional cold-air induction system. I made it in about an hour, for about $30. It mates up to the hood scoop and draws nearly all inducted air from the scoop. With this induction system, coupled to the stock Quadrajet, ported heads, intake, cam, torque converter, and headers, my 305 cruised to nearly a 13 second quarter mile. That's 1.5 seconds and 13 MPH faster than one year ago.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Daniel Burk
slick move man. I think that K&N filter top would really be sweet on ur set up. U know what im talking about, that lid with the filter in it. It would be prefect. did u notice an increase with just this mod alone?
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
system: 2 10" MTX thunder 2000 in a Professionally done custom bandpass box.
Blaupunkt CD player
Blaupunkt 4x6 and 6x9
600 watt rockford fosgate 4.6 amp
http://members.aol.com/j007golden/Mikey89.html
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
Blaupunkt CD player
Not bad, looks good Dan.
I made a pan similar to that when I made a friends cowl hood functional for his 2ndgen. Here's what I used, all parts from Home Depot.
$10 Aluminum sheet
$4 some sort of clear calking glue
$5-10 3" thick weather stripping foam
$? self tapping screws
Fair warning, make sure your throttle cable is not hitting the pan (aluminum sheet) or it will stick and your bound to hit someone or something.
Sites to help inspire Carb/TBI Firebird owners.
http://www.smokemup.com/tech/coldair/coldair.cfm
http://msnhomepages.talkcity.com/Hob...fbody/air.html
1989 Camaro RS LO3 WCT5 "The Hose Queen" 0-60' 2.34 1/4 15.8@87mph
http://350.StreetRacing.org
$10 Aluminum sheet
90formulaVortec
Sep 8, 2015 12:42 AM
