MPI conversion
Old Dec 1, 2000 | 08:32 AM
Dan W's Avatar
MPI conversion
I'm thinking of a MPI conversion on a weiand street ram intake. (In preperation for boost in the near future) I'm probably going to use the 4bbl holley TBI unit to meter air for at least a while.
Does anyone know of a kit or someone who sells the parts to convert a carbed type intake to multi point? I need the lines, injectors, rails bungs and regulator.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter
350 .060 over with forged 1 pc rms crank, and forged TRW pistons, 9.5:1 cr
Factory GM heads Pocket ported, 2.02/1.60 valves, back cut
Comp Cams roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Edelbrock Performer EGR intake, Edelbrock TES and 3" cat
Old Dec 1, 2000 | 10:36 AM
Tas's Avatar
Tas
check my efi page. Accel and Holley should have all that stuff. But first try to see of TPI rails fit and use SVO injectors. I want to do it too. your 4 barrel is perfect to use. Holley wants $600 for their 1000 cfm 4 barrel TB. let us know how it comes out
-Tas
'89 Formula WS-6
[soon to be Performace Red =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
ICQ 82881207
Old Dec 1, 2000 | 10:47 AM
Brent's Avatar
http://www.force-efi.com/ http://www.rancefi.com/
no endorsement blah blah blah
just some links I have.
Old Dec 4, 2000 | 08:59 AM
FastBroker's Avatar
Holley/Weiand has all the stuff for that manifold. Like $180 for rail/connector/regulator/line kit, manifold about $225 ish. Gonna do thatmyself but not sure if I am going to buy some more VORTEC heads for the motor I am building... I guess I could buy the Vortec manifold and have it drilled for "regular" intake pattern...
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
