Attn: 91Bird305
Old Dec 4, 2000 | 11:35 AM
EROCK's Avatar
Attn: 91Bird305
Eric,
I wanted to ask you about your posi. Which unit did you get? I see you have 3.42 gears and just wondered if you got the 2 series one or the 3 series one. I want one but are unsure which one to get since I still have the 2 series carrier with 3.73's. HArd to install?
Eric
Teal 1991 Camaro R.S., T-Tops,
Leather, Re-worked 700r4 also w/kit,
MSD ignition, MSD 8.5 mm. superconductor wires,
MSD Coil, ADS superchip, Open element air cleaner,
K-n-N filter, Gutted cat, Flowmaster cat-back system,
Edelbrock TES headers, March 3piece billet underdrive pulleys
3.73 gears
http://www.geocities.com/gitarz2/camaro.html
I was shocked to see that companies sold a taillight
set for a rustang! Since when do they have taillights????
Old Dec 4, 2000 | 05:30 PM
BLUE92RS's Avatar
I got mine form slp for $99. It is the take off unit from Zexel. Its a 3 sereis and is used but only for about 10 miles. Mine came in great shape and for $99 you end up saving about 200 to 300 dollars.
Old Dec 4, 2000 | 05:37 PM
BLUE92RS's Avatar
How did you remove your speed limiter. Is there anyway to do it besides what the tech article said. Sounds complicated.
Old Dec 4, 2000 | 06:41 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I bought mine used and it was a carrier 3 posi unit. I had to get rid of my 3:73's because they were made for a carrier 2 unit (my stock unit I had in at the time aka Peg-leg rear) so I had to sell the 3:73's. I didn't install my gears or posi. With gears you have to make sure they are lined up perfectly or you can mess things up I guess. So thats what I did, I just gave them to a well-known mechanic in my county and he put them in for 175.00 bucks. As for the speedo gear, I took mine to this local place called specmo. They calibrated it for me and gave me a new speedo gear to put in.
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
[This message has been edited by 91Bird305 (edited December 04, 2000).]
Old Dec 4, 2000 | 10:27 PM
mike ghoul's Avatar
there is a much simpler way to remove the speed limiter. I have 3.73 rear. All you need to do is get a new chip that has that programming removed. i got one from FAST CHIP. just make sure you tell them to remove the limiter(i believe this is automatic if you get the stage 2 chip) plus you'll get some performance gain.
Keep in mind HYPERTECH chips DO NOT remove the speed limiter, so go with another company, and be sure to double check.
1990 Camaro RS
305 TBI Auto
K&N Open Air Element, Edelbrock Performer Intake, Edelbrock Headers,Catco Hi Flow Cat, Edelbrock Exhaust, Hypertech Underdrive Pulley's, Jacobs Ignition, Fast Chip PROM, B&M Shift Kit, B&M Mega Shifter, 3.73 Rear with Auburn Limited Slip, KYB GR2 Gas Shocks and Struts, Eibach Pro Kit Lowering Springs, Edelbrock 3 Point Strut Tower Brace, Baer 13 in. Slotted Rotors with Metallic Pads, American Racing Torq Thrust II 16x8 Wheels with Toyo 245 50 VR 16 Tires, 3 in. Cowl Hood, A little weight here and a little weight there.
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
90TA
Jan 20, 2003 09:05 PM
cobrakiller1989
Oct 29, 2001 02:04 PM
91Bird305
Feb 12, 2001 05:20 PM
91Bird305
Oct 15, 2000 11:20 PM
