Mod Suggestions?
Old Dec 4, 2000 | 06:17 PM
MercenaryX's Avatar
Mod Suggestions?
My friend just got his first v8, its a 88 Firebird 305 TBI. What products do you guys recommend for a tune-up? Plugs, Wires, Cap, Rotor, Etc. Does his car posses the infamous "peanut" cam? And what mods should he look to if he wants 13's?
Old Dec 4, 2000 | 06:49 PM
Zac's92's Avatar
Yes it does posses the peanut cam (179int. 194ext. lift in .300's on both sides). Get any aftermarket cap and rotor and some good 8mm wires and some good delco plugs. For 13's first start with open element and ultimate tbi mods, then do complete exaust. Headers, 3" exaust, no cat, aftermarket muffler of choice. next get a set of gears 3.42's or 3.73's the latter if it's a 5-speed and a slp take off posi for $99. Once that is done buy some aluminum heads with 58cc cambers(vette or ZZ series heads) and a good cam along with a intake. On top of that slap a 670cfm TB and a custom prom to make it run nice. At this point you'll need some suspention work like sfc's, lca's, and a phb. Slap a set of Drag radials on there and a 100 shot of nos for good measure and you'll have one hell of a car.
Zac Spalding
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Well he is a long ways away from running 13's with that LO3 I am afraid. Stock they run between 16.4-15.9 As for a good starter mod for wires and such. I liked my setup. MSD 8.5mm Superconducter wires, MSD Cap & Rotor, MSD Blaster Coil and AC Rapidfire plugs. You can go with different companies like Accel and Jacobs too. But I like the MSD stuff. If you want send him my second website in my signature. The one about modification evaluation stuff. I documented all my mods, took pictures of them on the engine & car and wrote about what to do and what not to do, if it was worth it and good setups for 1st TBI guys. Check it out, I bet it helps out a lot.
Eric Natzke
91 Firebird 305 TBI (ZZ5 summer of "01")
ASCD Ram Air Hood-3" custom exaust-Flowmaster 80 Series-No Cat-Edelbrock TES Headers (coated)-March Pulleys-TBI Spacer-K&N Open ELement-TransGo Shift Kit-B&M Supercooler 28,000 GVW-Hypertech Thermomaster-160 Stat-3:42 GM Gears-Auburn Posi Unit-Edlebrock Strut Tower Brace-MSD Superconducters-MSD Cap & Rotor-MSD Blaster Coil-Rapidfire Plugs-265/50/R15 Tires-Emmison's all Gone
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Dec 4, 2000 | 09:04 PM
chevyboy07 91's Avatar
Zac '92 put it right on the money>>>>>>>even w/o NOS you WILL be in the 13's. To those who disagree>>>>>cause there is always someone. Do it and then tell us if it doesn't work. B/C first hand>>>it will. Nice & Easy on those mods>>>>>take your time and do it right. She'll run forever.
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Dec 5, 2000 | 06:55 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, all u have to do to get into 13's are these.
1.aftermarket cap & rotor
2.good set of 8mm wires & plugs
3.Open element
4.Ultimate TBI mods
5.Headers
6.3" exaust
7.aftermarket muffler
8.Set of gears
9.Posi
10.58cc aftermarket headers
11.Aftermarket cam
12.Aftermarket intake
13.670cfm tb unit
14.custom prom
15.Better set of tires
16.LCA's
17.Shift kit
18.Most likely some sort of trans cooler to keep your transmission lasting as long as we can get it.
19.Misc. stuff like pullies, spacer, etc...
Gee and thats it. Your in 13's. Congradulations. Your in 13's and u don't have anymore room for improvments though so u will always be stuck in 13's unless u want to bore the engine over and do a power adder. Doesn't this all sound real cheap for 13's?
I don't mean to get anyone down about this engine but its probably the worst V8 GM ever made. But it can be made into a better V8 but it just includes changing the entire block and fuel system. I say just beef that 305 TBI up until u get bored with it and swap ur mods onto something better.
[This message has been edited by 91Bird305 (edited December 05, 2000).]
Old Dec 5, 2000 | 12:09 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
some typos there, but good list. you forgot strip the interior, fiberglass hood and doors, and remove the spare tire of course.
really, whats so big about getting into 13's. i say get a flame job, dump exhaust at the axle , a hood scoop, and fat rears, and just let everybody think your runnin low.
just kidding, then your no better than a *****.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Dec 5, 2000 | 12:24 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
HAHAHA. Dump the exhaust. Good one Nic.
Eric Natzke
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
