Cam question for 350 TBI
Old Dec 5, 2006 | 04:22 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
I previoustly put this in another forum but figured I will put it in here as well seeing as this is a TBI forum and you guys will be more familiar with this mod. I am looking to put a cam in my car, what cam would wake my car up? What do you prefer in cams?
Old Dec 5, 2006 | 07:40 PM
deadtrend1's Avatar
what are the specs on the cam you have in there? What kind of 350 did you put in? Is it a roller motor, or flat tappet?
If you had a stock LO3 (or even a LO5) i would say go with a LT1 cam. But we need to know what you got currently to give you some advice...
Old Dec 6, 2006 | 05:36 AM
Car: 1991 Camaro RS
I honestly have no clue, all I know is that it's a Jasper crate engine. I have no clue what the rebuilded it with. I imagine the stock cam.
Last edited by XxGeinNothingxX; Dec 6, 2006 at 05:39 AM. Reason: Automerged Doublepost
Old Dec 7, 2006 | 07:04 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
if your car originally came with a 305 and your car has all of the mods listed then i would serouisly consider checking for the correct injectors for a 350, and verifying correct fuel pressure under load, and definately some diy chip tuning. spend some time in the diy prom section. you are at the point where tuning on a "stock" engine would be benificial to you so you can see the trends when you change cams and heads or even go with a stroker/nitrous/supercharged/turbos. lots of knowledge over there
Old Dec 10, 2006 | 10:07 AM
Car: 1991 Camaro RS
I know when I bought the car last year the kid told me he put the bigger injectors in. I have know clue how to verify fuel pressure underload and I guess I will go read up on tuning, I wish I had people around me that knew how to do these things, I am mostly ignorant to cars, still trying to learn.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
