Re: .bin file size
Old Dec 9, 2006 | 10:06 PM
88-383's Avatar
Car: 1988 Vette
Engine: 383,AFR,MiniRam
Transmission: ZF6spd
Re: .bin file size
Got a quetion, I had my 747 truck dyno tuned and a custom chip was made for it. The truck runs well, but I'm planning on converting some of the info from custom chip into the EBL and take the remaining issues on myself.
My question is this, why do I get 32kb file sizes? With a USB pocket programer and AT29C256 chips, 7000hex start of device. I think it's normal and ok, but just looking for reasurance before I do all this editing.
KM
Old Dec 10, 2006 | 02:54 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
The 29C256 chip is a 32k chip, If you are just pulling the file from it, is the 4k bin stacked 8 times, to fill the chip.
If you use tuner-pro, you can you the stacker/splitter program to split it down to the 4k bin that you actualy use. Then when you modify it, just restack it back to a 32k bin to burn on the chip.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
Linson
Sep 21, 2015 01:08 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
