Distributor?
Old Dec 9, 2006 | 08:08 PM
kronos's Avatar
Car: 89RS
Engine: Lo3 bored.030 over, 230/480comp cam
Transmission: 700r4 10" converter
Axle/Gears: Stock G80 2.73
Distributor?
How exactly does our distributor work with TBI? Is it just by getting signal from the knock sensor and the tps or is it much more than that? If I went with a carbed setup would there be any way to make the existing distributor work?
Old Dec 10, 2006 | 07:48 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
i seem to recall a post about using the tbi computer as a timing comp and nothing else, if you're going carb you prob arent into doing the computer end of things so i would suggest using an mech/vacuum advance dissy. if you want to use the tbi comp for timing alone you allready have to buy all the same stuff you would use to tune the whole deal so, in my opinion its all computer or none at all.
Old Dec 10, 2006 | 08:33 PM
kronos's Avatar
Car: 89RS
Very well put, Thank you sir. Msd HEI vac advance here I come.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
