bad injectors??
Old Dec 26, 2000 | 07:14 PM
Mo's Avatar
Mo
bad injectors??
Has anyone in here had problems with their injectors? What symptoms do you have? We have an 88 suburban 5.7 liter TBI and it runs rough and dies sometimes and then will start and run at low rpms and then run normal all of a sudden. we think it might be clogged/ sticking injectors. Any ideas?
Old Dec 26, 2000 | 09:07 PM
Andy89RS's Avatar
I had bad injectors on mine. You can tell by watching them fire when it runs if they're bad or not. Instead of a nice clean cone of fuel, I had poor atomization and actual drops of fuel dripping from the injectors. It didn't stall, but replacing them with new flow matched injectors gave me noticably more power, and a much smoother and quieter running engine
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Dec 27, 2000 | 03:26 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
that sounds like a dirty IAC passage if you ask me, get some carb cleaner and spray some in the iac hole and let it sit for awhile then start the car and let it idle and spray more down the iac passage to clean it out
Old Dec 27, 2000 | 10:20 AM
REDBIRD91's Avatar
A
1991 Formula WS6 305 TBI
K&N 14x3" Open air filtercharger accel-8.8's,coil,cap,rotor,module.
poly's here and there.
245/50R16 255/50ZR16
3"catco cat
3" Borla cat back
more to come
mike_c
Aug 27, 2015 04:32 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
Bryan F
Aug 18, 2015 02:28 PM
