BLUE92RS
Old Dec 27, 2000 | 10:17 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
BLUE92RS
hows that cat comin? id like to hear and see it when you get it out of the system. If it wasnt too difficult, id like to take mine off too. along with all the other emmissions stuff.
IM: snflupigus | ICQ: 96787192
Snflupigus.com
Open Element Tech Article
ENGINE SPECS:
Stock Rating: 170bhp & 255ft-lbs
305 TBI,Open Element,K&N 14x3,Hypertech Stage I,454 GM TBI
Now Rating: A Little More
STEREO SPECS:
JVC Kalmeleon kdlx3,Infinity Kappa 2way 6x9's,PPI 4x6 Coaxials,PPI PC2400 AMP @ 2ohm
DEI Studio 12" 4ohm DVC,Custom Box:Exactly 1 Cubic Foot
Old Dec 27, 2000 | 10:48 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Hey snflupigus, sounds like you want to get rid of your cat converter. It's sooo simple, if you have a cut off tool that is. Just cut the cat right off, get a pipe that's the same size as your exhaust system, and either have it welded in or clamp it in (I suggest welding obviously). You want to remove the rest if the smog stuff too I see. That's easy. Start by removing the A.I.R control valve, which is held on by 2 bolts on the bottom (if I remember correctly), and the 2 wiring connectors. Next, remove the pipes from your exhaust manifolds and plug the holes, or do like I did and get headers with no A.I.R tubes (SLP suggested here). Then remove the A.I.R pump. 2 bolts here, their Torx headed. You'll have to re-route the belt and get a longer one. I have the length somewhere around here, I'm assuming you have airconditioning? I'll get yu length and a pic of the routing as soon as I can find it.
Hope I helped.
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Old Dec 27, 2000 | 10:50 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
BTW, you won't get any "Service Engine Soon" lights either, I've heard about that before and it's a bunch of crap.
1992 RS
Old Dec 27, 2000 | 11:33 AM
1989CamaroRs's Avatar
man i wish i dident have to get emmisions
-Stock Tbi 305 with a lot damn miles
-Edelbrock Z28 TES Headers
-3 inch CatcoHigh Flow Cat
-3 inch Edelbrock Catback
-SSM Subframe Connectors
Stereo
-Pioneer DEH-P4100 cd player
-Polk Dx9 6x9s
Old Dec 27, 2000 | 06:04 PM
snflupigus's Avatar
ya, im gona wing it, im sure i can handle that stuff. I was just wondering how hard it was to take out the cat. Or how long it would take, etc. im going to do it, and ill figure out how, i just thought ide see if there were any tips to take note of. I like to learn from other peoples mistakes so i dont make the same. o, and im just gona leave the smog pump there.
