manual steering options, pablo????
Old Jan 1, 2001 | 09:53 PM
NJ SPEEDER's Avatar
hey pablo. i have been looking around for the manual sterring box that you mentioned for my car.i am having trouble locating one in my area, trenton, nj. the parts stores don't even list replacement units available. can you suggest anyplace online to look for it, or any chain store that may be worth looking into.
i have 1 more salvage yard to check and i am gonna call napa tomorrow. any help is appreciated, i am running out of options.
thanks
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
The car is going street strip for next season. 13's here i come!!!!!
Edlebrock TES Headers, Cat Eliminator Pipe, Borla Adjustable Cat Back,Marche Pulleys, HyperTech Chip,Transgo Shift Kit,B&M Convertor(2000stall),Steve Spohn Rear Rig( all rod ends), Poly Front Bushings,Ported TB, 350 Injectors, Edlebrock Performer TBI Intake, Performer Heads, 1.6 Roller Tipped Rockers
http://www.mycar.net/mafb/registry/detail.cfm?id=299
Old Jan 1, 2001 | 10:25 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
i havent done the swap myself but ive heard from numerous people that the 86 S10 manual rack bolts right in thats the manual box i was talking about i hope i didnt make it sound like some thirdgens came with a manual box
Old Jan 1, 2001 | 11:20 PM
Basett Racing's Avatar
Pablo, is the manual S10 box supposed to weigh less? I currently have the pump and lines removed off my 82 Z. I screwed 2 fittings into the box and filled it up with P/S fluid, then looped a peice if the high pressure line from fitting to fitting. Its a little hard (a little harder than normal manual steering) sitting still but drives pretty easy when rolling. I do have 15X4 Convo Pros though, so it might be a B*#@H to drive with 8 of 9" tires on front, I've never tried.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 15.03@92.7
http://www.bassettracing.cz28.com
Old Jan 1, 2001 | 11:32 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
yeah basset.. ive heard all sorts of claims about it being lighter, from 30 to 50 lbs lighter for the entire setup (depending on who you ask) if i were running skinnies id go to it in a second and i still might, if my ps pump craps out you know ill be getting one
it'll definately be easier than turning the hyd. box with no pump
Old Jan 2, 2001 | 06:57 PM
Man, 50# would be sweet!! Hell, 30# would be too, and then I stop having to to go the gym just to turn mt steering wheel!!
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
