Can somebody help me
Old Dec 18, 2006 | 03:25 PM
freestylin's Avatar
Hi I am trying to do the open elemt air cleaner but every time i open the lik or try to open the directions it doesnt work would somebody copy and paste them dow below or email it to me please freestylin12688@yahoo.com
Old Dec 18, 2006 | 09:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
What speed is your connection?
The open element thread is quite long... Lets see if you can get it to open first before trying to capture it all. Have you tried another browser? Sometimes TGO does time out. Try another browser and see if it works any better.
Old Jan 8, 2007 | 09:02 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Are you talking about this here?:
http://snflupigus.tripod.com/tech/op...tep1/step1.htm
If so, just right click on it and hit 'save target as' to save it to your computer. You'll need Microsoft Word to open the file. If you don't have Word, you can download OpenOffice. It should let you open it also:
http://www.openoffice.org/
Old Jan 9, 2007 | 12:58 PM
D3ATH)(TR00P3R's Avatar
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
The open element install is very simple as long as you follow the instructions carefully. If anyone is worried about grounding out either get a cleaner with a smaller diameter or maybe try covering the bottom with electrical tape.
Old Jan 15, 2007 | 03:12 PM
freestylin's Avatar
i just finished the open element air cleaner pretty easy with the directions thanks di11avou i did dowload the app ad it let me dowload the instructions now that im done with that i also went to maaco and the guy told me estimate of 1500 thats unbelieveable cant i sand it down myself and then just have them paint it
Old Jan 15, 2007 | 03:35 PM
Untamed's Avatar
Car: 88 Trans Am
Engine: 305 TBI
You can do the prep work yourself, but Maaco will likely charge you an hour or two to "fix" spots before painting, unless you specifically tell them not to. They'll just "spray and pray" for cheap.
Just remember though, you get what you pay for. A paint job of $1500 sounds like a lot untill you see the paint jobs of other cars then went for $3000+ which are awesome.
Old Jan 15, 2007 | 05:59 PM
freestylin's Avatar
yea thats true im getting two new doors 2 fenders and a hood for 200 tommorow what tools would i need to take off the doors i know the hoods not hard and the fenders i dont really need
Old Jan 16, 2007 | 02:52 PM
Untamed's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Haven't removed doors myself, but I imagine the two pins should come out without removing the hinges. Unsure though. Might just have to remove the bolts holding the hinges to the doors.
Also, if you have power windows, locks, mirrors, you'll have to disconnect that part of the wiring harness from each of the items. So that means removing the door panel (which you would remove for painting anyway), the plastic water shield, then reach through the openings in the door to disconnect the harness from each item. Just drop that end of the harness in the footwell on each side.
Good luck!
Old Jan 16, 2007 | 03:09 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
painted my car with the help of my former boss, cost over 2000 all said and done and there was no labor at all. my car looks better then new but bodywork aint cheap homes. for a badass look that hides little ****, go with flat paint, inparticular flat black with some flat white stripes like car craft did on their 69' looks pretty wicked. alott cheaper too
