Stinky exhaust
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Stinky exhaust
I'm stumped here. I've had this problem for a long time now, and have no idea what is causing it. It smells sorta like there is fuel in the exhaust, but not exactly. It's kinda weird, but it stinks. It can't be the catalitic converter because I don't have one. The engine is a 305 TBI with SLP 1 5/8" headers, 3" exhaust and a Flowmaster 80. I think the engine is running rich, but don't know what's causing it or how to remedy it. Any sensors to check? Anything?
The reason they put cats on is to filter out the little droplets of gas that don't get burned up all the way along with all the other pollutents. So if you don't have a cat it isn't catching the unburned gas which iis why it smells kinda gasy.
Car: C1500
Mine has a cat and it does it in the morning after it has cooled off, usually in the morning. Mine does it because it's "warming up", just in enrichment mode, it goes away after it warms up.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
*****Possible summer '01 mods*****
Open Element, Auburn Posi, Keyless Entry, wonder Bar off the IROC, 4th gen seats, T/A tail lights
1985 Camaro IROC-Z LB9 Auto
http://www.geocities.com/krt80/
-180 degree stat
-Hooker Cat-Back
Car: 1986 Camaro
Axle/Gears: 4.10
Try a tune up on your car and if you have been running the same kind of gas over and over put in somthing different and see if that helps.
1988 GTA (29,000 original miles):
Crane Cam, K&N
Flowmaster, Off Road Pipe.
Crane Cam, K&N
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
New cap, rotor, coil, wires, plugs, O2 sensor, and it gets warm enough. Now, why does it smell? It's not from taking the cat off because other cars without cats don't make you stink like exhaust everythime you start the car, and my old 327 didn't stink at all.
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
I think it's my ignition system. It's not putting out enough power, and the mixture isn't getting burned up enough. I'm going to get a new coil and put an MSD system on, mabye that will cure my problem.
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
All ur igition stuff is stock right now Duke? I would try some igition mods then. I liked all the MSD stuff I put on my car. Made it run a lot smoother.
david068513
Sep 18, 2015 10:36 AM
that will rid you of a gassy exhaust smell
