oil
Old Jan 28, 2001 | 06:53 PM
TMoNeE's Avatar
Car: 87 Z28
oil
Hey, I went to replace my intake with an open element today and when i pulled the top off my stock... there was oil in where the air filter is.. Ive heard this can be due to a broken pcv valve or something like that, Sound right? if so, how do i fix it, where is it, etc etc. I need detailed info cuz im not mechanically inclined.
Old Jan 28, 2001 | 06:54 PM
TMoNeE's Avatar
Car: 87 Z28
Sorry I have an 89 RS w/ 305 TBI
Edelbrock 14x3 OE intake, Hypertech Chip, Street & Strip shift kit, flowmaster exhaust w/ high flow catco cat.
Old Jan 28, 2001 | 07:23 PM
NJ SPEEDER's Avatar
it's just residue fromt he breather that goes into the pass. side of the air box. there should not be enough there to puddle, but there will likely be a nice film over the bottom of the tray. if there are puddles the it means that oil is follwing up the tube a lot, either the baffle inside the valve cover is broken or you hafta stop taking left turns so hard.
lata
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Jan 28, 2001 | 08:46 PM
89RS355's Avatar
Like he said, it is probably from the breather. No big deal. Just make sure your breathre is clean.
FYI, the PCV valve is on the driver's side front top of the valve cover. Couple of bucks at any shop, and about 3.5 seconds to change. It's job is to allow engine vacuum to "suck" out fumes and blow-by from the crankcase. There is always a little pressure that gets by the piston rings, and to avoid a pressure buildup in the lower half of the motor they put this little valve in that has vaccum to help relieve any excess low end pressure.
Jerry
89 RS Lt Blue T-Tops T5
355 Crate, Compucam 2040
Pst Front Hotchkis Rear
Edle. TES 3" Flowmaster
Harwood hood, bla, bla, bla...
94 Z28, LT1 6M, Black
Most of the bolt-ons
Old Jan 29, 2001 | 07:49 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Also, check ur emmision lines. Seems like I remember someone saying they had oil in the air filter and it was because one of the emmision lines was kinked and the oil that usually flows through there had no choice but to go up into the filter assembly from the breather. Just a thought.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
