Need Some Help
Old Dec 31, 2006 | 10:14 PM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
Need Some Help
ok i have a 4.3l TBI that i cannot figure out! the problem is that when the engine warms up it has almast no throttle response unitl the RPM's raise! when its warm from a dead stop when i give it gas it tries to fall on its face and will even backfire through the TB (can this happen?) i ran the codes (the A B test) and came up with the o2, map, vss, and knock sensor, i replaced the o2 sensor since i knew it was bad, checked the codes agai after resetting the computer and all it gave was the 1, 1-2 code. as far as i know that means all is good with the sensors. so why is it still stumbling around?? by the way the speedo does not work this is in a 92' cheyenne and it does not have a cat. any help i can get would be awsome!! thanks
Old Jan 29, 2007 | 04:06 AM
Car: 1991 camaro rs
Engine: 3.1
ttt
Old Jan 30, 2007 | 11:08 PM
Home Built's Avatar
Check the tps..
Might be bad..
Old Jan 31, 2007 | 08:31 PM
Car: 1991 camaro rs
Engine: 3.1
i thought about that could but, would it cause my speedo not to work?
Old Jan 31, 2007 | 08:41 PM
Car: 1991 camaro rs
Engine: 3.1
