no heat - help quick
Old Feb 18, 2001 | 06:01 AM
TMoNeE's Avatar
Car: 87 Z28
I put this in tech but they suck and the guys in here are smart so help me out. The other day I turned my A/C on for the first time all winter because it was hot out. Ever since then, i have NO heat, i put it back onto heat and it blows cold air.. coolant level is good, but im not very mechanically inclined so I dont know what would cause that to happen... up until the otherday my heat worked great.
89 RS 305 TBI
Edelbrock 14x3 OE intake, Hypertech Chip, Street & Strip shift kit, flowmaster exhaust w/ high flow catco cat.
AIM:TiMoThY9801
Stereo:
JVC Detachable face cd player w/ 2 Pioneer 12" subs in custom box, powered by Lanzar 600 watt amp.
Old Feb 18, 2001 | 07:05 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Go down on the passenger side and feel the carpet under the dash. If it feels wet there then your heater core has gone bad. Also, if it smells kinda funny when you turn your heat on then that is another sign of your heater core going bad. Run your heater for like 15 minutes and check those things first.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Feb 18, 2001 | 10:21 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
sounds like a cable problem, how old is your car, you might need to just take the heater core apart and clean it out. pita yes but heater cores are expensive and usually cleanable instead of replacing. check your blower motor, they always go out when its really cold. most likely, unless its you contol head cable broken or something, these are just coincidence. sounds like you got some componant checking to do. good luck
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
